Noob Q's Here!
asdfasdf128
NJ
Figured since we dont have a noob section, I'll create a thread where we can post up noob questions :idea2: SORRY FOR THE NOOBNESS guys. :roflol: I'll start:
I need a tool to adjust my chain (add/take out links). What would you guys recommend? Also where can I find the actual link that comes with a tiny clip to hold the entire chain together? (mine fell off and I cant find it anywhere)
CoyCaller
New to go karting
Broken Bow, NE
You need what is called a chain breaker. You can usually get one at a hardware store along with your new connector links.
You can also grind or file the ends of the pins on the link to be removed and drive them out with a hammer and punch. These tools can also be bought at the hardware store. I recommend this route as these tools are more versatile and you probably already have them. The chainbreaker is nice but will hardly ever be used.
Rickracer
RM250 Race Kart Driver
Kissimmee Fl.
You really don't want a master link, the chain breaker will separate and reconnect the chain without using a master link.
This is the best kind of chain tool, IMHO:
http://www.qrckarts.com/store/index...&Product_ID=120&CFID=8442815&CFTOKEN=45759515
anderkart
Surprise Arizona USA
:iagree:
When I first started out using master links, all my kart buddies made fun of me till I bought a chain breaker and taught myself how to corectly use it.
Rickracer
Kissimmee Fl.
The style of chainbreaker that was posted pushes the pins back in just as it was when it was manufactured, ;) :cool:
Kart builder39
if you dont have cash to buy a breaker ,,just take you chain and put it in a vise , center punch the pins out to get chain apart then get vise grips to press it back together ...works every time
lemegacool
got boost? :)
quebec canada
the breaker i have really breaks the chain... i absolutely have to use a masterlink to get the chain back together...
the center punch method might get frusrtating if you punch out the pin completely out... good luck getting it back in LOL
porsche930dude
Upstate, NY
you dont have to grind off the ends. i dont even punch one pin all the way through. i just tap out both sides a little bit so one side plate comes off. When i first found out it was possible i went crazy and made a few long chains out of about 50 short sections i had lol
Kaptain Krunch
Pro Junk Collector
vermont
WELL i wouldnt trust a tecumseh ungoverned myself. But to take out the governor simply drain the oil, remove side cover, remove plastic governor gear, remove governor arm, and plug the hole where the governor arm was with a bolt. Then you just need to rig up a throttle cable directly to the carb.
In my house
i dont think i'm going to go threw all that just yet. i mean i already got oil leaking from where the governor arm comes out of the engine block but i keep the oil in it so i should be good for now...when it blows im going to Kholer
asdfasdf128
NJ
if you could, maybe you can take some pictures outlining the process, and we can add it to the website. (maybe we can even get a "how to" section :) )
In my house
How to...
If we could lets talk to someone about not only the NooB section but a How to on simple and maybe even some complex mods and repairs. That would make this site alot more interesting and easy to navigate threw.:censored:
freakboy
the names 'mater
hick town
Ill sugest it for ya guys alright. and its alredy been sugested idk if robert wants to go through that.
