Hello. My son and I are building first kart and are a bit stumped on a few things. From the photos we were hoping a few could shed some light…
This build comes from a $50 frame my son found – we have no idea its make, possibly just a backyard project frame as I can’t find markings anywhere. No roll cage, no seat belt, no side guards. Front pedals have this rubber tubing arching over column and connecting them – seems a bit weird but maybe allows for surer contact with pedals in turns, etc.? Has welded tabs for other fittings it seems. Seems odd not even a seat support though. Anyhow its grown on us as a frame!
We did a stage two on a new pred 212. Everything but the gov removal and 18lb springs. Figured we’d go this far, and see how it goes. Added a TC 30 with 12/60 sprockets and 35 chain. 14” rear turf with 12” front tires. (Had 12’s all around originally, but needed more clearance.) 1” live axle. Added a forklift seat I found on northern tool.
It runs great and seems pretty powerful but having darndest time keeping it from throwing the 35 chain. Did all the alignment tricks, straight edge, etc. Originally, I added thick rubber bushings on the mount and engine plates to help cut down on vibration. I’m beginning to think bushings are allowing engine to rack a bit under load and in turns.
Planning on going to 41 chain but sprocket will need to be pretty big to maintain 6:1. What do you think? Would 5:1 be ok for this set-up – mostly off-road/yards? 35 chain was a cheapo with aluminum split sprocket. Like aviation all these things together might add up to our problem.
Thank you for any insights!
