how much do raptor engines normally go for?
$40 apparently haha.
If it was me wanting to fix up this engine a bit, freshen it up if you will I would
1) see if the valve guides and lifter guides need to be drilled and replaced with bronze guides. They are relatively inexpensive and can be done with a hand drill and maybe $20 worth of tools. A lot of times the exhaust valve is really looose, and can cause a lot of smoking. Use some sandpaper to put on the valves then "sand out" the seats, then do a fine lap with lapping compound.
2) check bore to see if it is even worth working on. If it is a cool bore (no steel sleeve), then I wouldnt put much into it.
3) check for cam/connecting rod. If it has a nice rod (which i doubt it has as it doesnt have a nice carb on it, might just be a run of the mill stocker engine with a header on it to be honest. If its cool bore, and has a stock rod, check rod clearance with plastigauge and maybe replace the rod with another stock one if it is out of tolerance. Typically .002-.004" of oil clearance is what the tolerance is.
4) if for some reason it has a nice rod/cam (again, don't get your hopes up) look at the ports, are they ported? That would give you some good gains.
5) if it has nice rod/cam consider upgrading the carb to a pz20 or pz22 carb. That will really wake it up.
6) see if you can ditch the starter mechanism on that thing. They are TURDS. I actually ended up chopping mine off, then using the nut from another briggs to secure a honda/clone cup on there and used a honda/clone recoil on the briggs. Works like a charm.
