camaroman7d
Should be no issues(I usually run a 5:1 on my karts) if your wheels are 10"-11", and if the over all weight(w/ you on it) isnt too much for the motor to push.
I would personally run a 6:1-6.5:1, for a barstool, for starters... the center of gravity(CoG) is so high youll more than likely tip over your first turn(unless you make it about 40" wide and equivalently proportioned correctly... but then, thats a go kart w/ a stool for a seat).
So you would gear higher ( numerically), to limit top speed? Or so it would have more low end? As far as tipping over one has to be smarter that the stool they're riding. I don't plan on racing around corners at high rates of speed I just wanted to build one for a long time. If I can pull a few wheelies and scare myself a couple times (even if that means tipping over) then the project will be a success.
I didn't build it like your typical bar stool I will post pictures soon. I used mostly what I had on hand. It is longer than out I have seen. Seat height should be about 26". I'm 6'4" 235 so the little bar stools you usually see won't cut it.
