Newbie from OKC
ridin_low07
Oklahoma City
Hey whats going on folks? I'm new from Oklahoma City as you can see by the title. I am especially new to karts. I have quite a few various little projects laying around that I am working on. My normal jump and go is a Baja Warrior with a Predator 212cc and TAV2 along with a custom exhaust.
I recently acquired 2 Doodlebug frames that I have swapped X18 Front wheels on as a start to Christmas projects for my daughters, 9 and 6. The 9 year old is stoked for a mini bike, but alas the 6 year old decided she wanted a Kart instead.
I have had a Razor Dirt Buggy for a few years that the kids have outgrown so I took it on as a project for the youngest. I pulled it onto the porch today, chopped the rear end apart, and tack welded a rear end that I had laying around onto the previous supports.
I have figured out that it came with an odd axle size as the axle is a bit over an inch in the center, turned down to 22mm, and finally finishes off around 3/4". Its an oddball for sure. I have found new bearings on amazon that will allow me to run a 3/4" keyed axle.
I am planning on running a 3/4" live axle with the sprocket on the left and disk brake on the right. I also plan to use Riding Mower rear wheels for a nice beefy size and Riding Mower front wheels as the fronts. The issue that I am having at the moment is figuring out how to install the Mower wheels on the rear. I haven't ordered anything as of yet so everything is still up in the air.
I am open to suggestions as well. Pic of said project is below. Right now it is mocked up with a 3/4" weldable rod passing thru with the mower fronts slid on. I am thinking 36" axle to give it some good width out back and I will build my own spindles up front as well. Look forward to hearing from you folks.
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
ridin_low07
Oklahoma City
So you just reused the old axle? I am making mine a bit beefier to be able to play in the grass and hills really well. I have a 97cc that came with my doodlebug that I am thinking about using on it
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Well I started out trying to use the 20mm Axle. It was too narrow, and difficult to find hubs and wheels for.
I explained that in the thread. And the second kart the Gold one, came out better.
I ended up using a 30"wide 3/4" axle.
ridin_low07
Oklahoma City
Thanks bub. I'm leaning towards 36 just to make it nice and wide. I've got to do a honda minimoto for a friend of mine soon as well.
Greetings, stranger.
Remember, the wider you go axle-wise in the rear, the harder it will be to effect a turn. More so if you have wide tires.
Neat looking kart as it is in mocked-up form. I like the headlights--never seen anything on a kart that is quite as "serious" as those. :D
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
I wish I could find a cheap Minimoto. I think a much better platform to start with. :thumbsup:
ridin_low07
Oklahoma City
Yeah I had em laying around while the kart was still electric so I put em on. They have H4 LEDs in them. After I get this all put back together I will have an LED bar across the front instead.
---------- Post added at 08:38 PM ---------- Previous post was at 08:37 PM ----------
Yeah he picked it up for around 200 but most of the body is gone. Gonna be putting a predator 212 on it with a 60 tooth sprocket.
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Throttle stop is not good for Cent Clutches.
I say let them learn to go fast!
In that Kart throttle control will be a great way to learn steering and Kart control.
ridin_low07
Oklahoma City
Maybe it's just me, but the cart looks as though it was just pasted into the picture?:huh:
Well here are a few more to clear that up for ya
ridin_low07
Oklahoma City
No sir. Just 3/4 flanges. I am trying to find a way to build a hub for not only the wheels but to mount a sprocket on the left and disc on the right.
ridin_low07
Oklahoma City
Awesome. I will check that out. I am doing my ****edest to not just weld the wheels to the axle and throwing the motor on lol. This kart business is a little more time consuming than the mini bike world.
