new wheelbearings still binding
ohsoblue92
Hello again all,
Another quick question. I have a manco 415 two seater that I have just recently installed new wheel bearings on (the last ones were junk) anyway when turning the wheel hard left or hard right the wheels tend to bind up. I am thinking that I am missing a washer on the outside and inside of the wheel.... Anyone else happen to find that thir wheels bind when turning.. Thanks........
firemanjim
Just kartin' around....
Houston Texas
You should have a spacer (cut from tube) inside the wheel, that fits between the bearings. This let's you tighten up bearing bolt without binding bearings. It holds the races rigid.....
Poboy kartman
Senior Moments Member
White Settlement Texas
You should have a spacer and a small 5/8" washer on the inside. Just the locknut on the outside....it's small enough that it only engages the race....
ohsoblue92
Excellent, Thank you for the info and the Pics.... I really need to source those spacers so off I go in search of them.... BTW I like the spring spindle set up you have there in your pic. Little dudes cart is a rigid mount and he probably weighs a whoppin 60 lbs or so so he bouncs all over the yard!!!!!!!!!
Poboy kartman
That's all stock Manco 415-09 D stuff.... (Red Fox2)....Go to gokartsrus.com and look for manuals on the left. Punch in yours and you will get a download of all the parts needed and you can most likely get anything you need that your kart originally came with.
If you need. ....I can pull a wheel and give you exact dimensions on what is there......
ohsoblue92
Thanks for the help. I went down to the local Tractor Supply Store today and they had 5/8 spacers there. I bought one and cut it down to size and boom, problem fixed. Thanks for the pics and heads up.... I appreciate it......:cheers2:
I assume he fixed it like Doug mentioned below??
