New to go karts and need help
Tex
Building 2 karts for the kids and ran into an issue. Don’t know the make and model of this kart but was told it’s an Otasco. Trying to find a new drive wheel. Kart has 3/4” solid through axle. Uses 4.10/3.50 - wheels. One of my kids bent the drive hub.
Blake W.
Independence, KY
I'm new here. I wish I could help. I'm just trying to identify my sons kart manufacturer. I like the green. Good luck brother.
Blake
JTSpeedDemon
2019 Build Off Winner!
Texas
Your best bet is probably www.ombwarehouse.com , but other good places to check are:
www.mfgsupply.com
www.bmikarts.com
www.gopowersports.com
You need to measure the bolt circle to positively find the right one- WHAAAAA????? That's a 6 bolt hub??? That's unusual. You may not find anything, but it's still worth checking.
You may need new wheels and a new sprocket, then you can switch to a conventional 4 bolt hub setup.
Tex
I plan on changing both. Thanks for the places I should check. I’ve ordered parts from MFG and GoPower. Will check the others.
Tex
Thanks for recommending OMB! Eric was the most helpful tech support I’ve called. Got me setup with all I need to get my kart back burnin rubber.
