Iv'e recently started a new project regarding an old go kart, and my plans are to swap an old predator 212 with some modifications, for a brand-new Lifan 200cc 5-speed. I bought the engine from ebay (http://www.ebay.com/itm/LIFAN-200CC...ash=item2a2997e783:g:SdMAAOxyi-ZTYZ~A&vxp=mtr) I need help because I have no experience with electrical things on engines, wiring is very new to me. I've taken advice from somebody regarding problems with the connector pins being in the wrong spot, but i have no idea how to wire the entire thing together. I have a battery coming in the mail, which i'm guessing i'll need. From my point of view, every single wire, plug, and other parts connected to those wires and plugs make no sense to me. I would greatly appreciate help with the wiring. I also need help with assembling a lot of other parts on the engine such as attaching fuel line to the carburetor which doesn't fit well, the fuel line is a bit bigger than the fitting, and I also need help with the exhaust. The problem with the exhaust, is that I can't find a single pipe online that would fit this engine, I bought one pipe and it didn't quite fit. A big problem is that mostly everybody is putting this engine in a bike or some sort of frame that fits it perfectly, but since I'm putting this in a go kart, I have to do cut and weld the pipe so its not sticking 3 feet out the back, to be honest, I'm completely capable of doing that, but i run into problems when I try to fit the pipe to the exhaust port on the engine, nothing online tells me that it definitely fits a lifan 200cc engine, most of them say "LIFAN HONDA DIRTBIKE ATV PIPE" some say 110cc 70cc 150cc etc, but I haven't found one that supports the 200cc engine. Any help would be great. If you need any links or anything, ask. Thank you.
