Diy motorsport
Hey guys so I’m putting a predator motor in my daughters quad and it won’t run right at all, first off I removed the original exhaust and put on a straight pipe, I took off the fuel tank and I cut the air filter housing all up to fit! I have a filter in it but it runs the same with or with out the filter, so my issues are I can get it to run with the choke on at a 1/4 throttle and above and if I block off the intake completely it runs a lot better but it won’t run with the choke off unless it’s wot! Any suggestions? I can’t trade it for a new one due to what I’ve done to get it to fit, do you think a stage 1 carb kit would fix it or do I have other issues?
