I wrote and deleted my thoughts about the ethics of claiming warranty at this point, all I'll say is that I think it's questionable - and who wants that?
Moving along...
...my chain is still very loose i believe it is what is causing the slower acceleration and slower top speed. ...
Nope. The only way a chain would affect performance was if it was so tight it was overloading the bearings and causing drag -and it'd have to be really really tight, or if it was so loose that it came off. All the chain does is transmit power. If there's an issue with acceleration or speed, look at the engine.
My bet is that (1) your first throttle setup came loose somehow and 'tricked' you into thinking you'd lost power, or (2) by overspeeding it you've scored the piston / cylinder walls and/or rod / crank bearing surface, and it's running "better" now because it has knocked the worst of the scored parts down. If so, it may well run for years like that, or it may go ahead and seize up tomorrow.
The only way to know for sure is to open it back up and take a close look.
