New mini bike project
fast92rs
Old Bridge, NJ
Just picked this guy up for $80. A little rough but pretty cool with that wide rear tire
Sent from my SM-G900P using Tapatalk
Iron John
NA
I like the combination sprocket and brake. That's one fine-looking machine, BTW!
fast92rs
Old Bridge, NJ
Got new tires on it today. Going to put on a tourqe coverter set up on it and wire a new kill switch.
Nice score. I'm envious as these old skool types are in short supply it seems.
I'm definitely a Briggs fan so I can only offer that maybe it needs a header with a chrome tip or similar and only because it's a bike. Makes it look right. :sifone:
Clone is already sporting the much better, less-restrictive OEM straight muffler. You gonna run it on methanol? ;)
Front fork looks a little bent.
fast92rs
Old Bridge, NJ
No just 94 octane. I thought it was bent as well but when I Googled pics of other bikes of the same model tgey all looked the same as this so not sure.
fast92rs
Old Bridge, NJ
Getting it all stripped done. Welded up a couple cracks and filled in all the holes I don't need.
Iron John
NA
Those front forks bent back from someone in the past going all Eveil Kneival on it?
fast92rs
Old Bridge, NJ
Don't know. Got it like that. Seemed to ride ok like that. Will try and straighten it out when I finish stripping it down.
With chains that long, I've seen some that have a tensioner wheel located on the frame halfway between the sprocket and the clutch...
fast92rs
Old Bridge, NJ
Getting the torque converter mocked up. I decided to use a pmr motor mount plate to lift the engine up.
