New Member needing help!
baldchicken
Hey gang, and thanks for the forum.
I recently inherited a Roketa GK-37(KTX-90). When I got it, it didnt work (no spark, no battery, needed LOTS of TLC).
So proud to say, I busted my hump and cleaned it up. I was able to remove the throttle cable and put some starter fluid in there and worked until that fuel was gone.
ISSUE:
I went to start it up again, and heard the smallest click. Now I have no power to the horn, engine doesn't even try to turn.
Any ideas what could cause this? No power to anything? Can a bad Starting Relay Solenoid cause no power to the entire vehicle?
WHAT I HAVE TRIED:
I replaced all the electrical components (except the starter solenoid). Just in case one of the NEW components went bad, I swapped them with the old (still nothing). I tried to bridge the start solenoid (which usually sparks), but that doesnt even spark. My volt meter shows that the solenoid is only 7V (I think it read 12V before).
VERIFIED ITEMS:
-Battery has 12V (verified with volt meter)
-Verified that the key is ON
-Removed the Kill switch cable voltage reg.
Side note: I changed the oil (and I thought that I pulled the proper plug, but can someone verify for me?)
It was the big one on the bottom (size 17mm or 18mm). It seemed like oil, but now I am seeing posts about filter drain and oil drain.
Thanks!
baldchicken
It's not the fuse (verified that). If the starter gear is jammed, would that prevent power from going through the vehicle?
Like I said, the horn doesnt work now, and when I used to bridge the solenoid (it would spark and blow the fuse), but now I dont get a spark nor a blown fuse.
It sounds like you have a bad battery. I have seen many batteries that had good voltage but would fail a load test. Remove battery and take it to you're nearest Advance or Auto Zone and have it load tested. And may the force be with you. :thumbsup:
I'd say a bad connection on the battery leads, most likely a bad earth; check where the negative cable connects the the frame...
Just one small point, this is the intro section; please post any questions in the correct sub forum...
baldchicken
You are correct!
I got eager and posted here. I believe you were correct, I reconnected the battery and it works :)
Ill keep my post to the appropriate location, and appreciate your help!
