new live axel
lgallagher59
Cape Cos
HI everyone, i am new to go karts, my first was a dead axel. fun kart.
i just got a live axel with 20 inch wheels in the back. i put a new 212 on it with a new 10tooth clutch and 60 tooth sprocket. it will crawl but not go fast and the clutch is smoking. Are the wheels to big and whats the fix? thank you
lgallagher59
Cape Cos
Would a tourque convertor also fix the issue if i want to keep the tires?
---------- Post added at 03:14 PM ---------- Previous post was at 03:13 PM ----------
Also when you say much bigger sprocket are we talking 72 fixes it or bigger?
lgallagher59
Cape Cos
Photos
Here is the current set up won’t move and smokes clutch
lgallagher59
Cape Cos
Also anyone tell from photo of the belt is a good tension? I am not sure what people mean by 1/2 inch of play
---------- Post added at 06:03 PM ---------- Previous post was at 06:01 PM ----------
I am leaning toward the tourque converter, will I run into any other problems with the sprocket I have on now?
That dingo needs a bigger engine. Those came with 8, 9, and 10hp engines. It also needs a torque converter.
Try this. Take the chain off and see how well just the rear axle spins. You might have bad bearings or locked up brakes.
---------- Post added at 07:21 PM ---------- Previous post was at 07:20 PM ----------
While your checking the bearing might as well check how well the fronts spin also.
There is no belt... that is a chain..
The deflection is 1/2"
anickode
S.E. Michigan
6:1 is awful high gearing for 20" wheels on an off road kart.
If you put a chicomet 30 series/TAV2 on there, it would help massively, otherwise you should be looking at a 7 or 8 to one drive ratio.
Even WITH a TAV2, you should consider upping the gear ratio, but it would at least move.
lgallagher59
Cape Cos
Thank you, the axel spins freely with out the chainI am going to try the tour we converter. Should I also change the ratio? Not trying to race it just have fun.
Is this a dingo?
lgallagher59
Cape Cos
So based on it being a dingo with 20 inch tires what is my best sprocket size. Again I am not looking to break any speed records just have fun. And I will be getting the torque converter so please factor that in. Also thank you all for the help.
lgallagher59
Cape Cos
Hi guys need help I am adding a torque converter index to move this sprocket to the right about an inch and I can’t break free I removed all bolts am I missing a set screw?
B.M.800
TheBeal.
Central PA
Spray it with some penetrating oil. PB Blaster, Liquid Wrench ect. Some gentle tapping. Be patient with it, dont hulk out on it. Ittle move. :thumbsup:
