New here need help
JBkartman
I would definitely go with the 40 serious but i would have to come up with a jack shaft idea here is pics of the kart. This is the older engine on it, i have not yet mounted the new 420cc predator.
mysteryboy28
Lansing, MI
holy chain travel batman! that's a long ways from the motor to the axle. you're gonna want to reinforce that frame, and i would seriously consider shortening the back end of it about 12 inches first! shorter wheelbase also means better turning radius too.
and while you're at it, might as well add a simple swingarm and shocks for rear suspension! yay! you'll have to cut the brake rod and run a (heavy duty) cable from the swingarm back to the caliper (or mount a lever on the swingarm hinge to extend the brake rod on), but it's totally doable. :)
mysteryboy28
Lansing, MI
that back plate is designed for the Comet 30/TAV2... i don't think it will accomodate a Comet 40, because it's bigger, and the belt diameters are different than the TAV2.
if anyone has had success putting a Comet 40 on one of the TAV2 backplates - please post it here, with pics if possible!
spyder1968
New Bedford, MA
another vote for a 40 series ! i have been running one on a 16+hp engine for a while and as long as it is geared correctly, it will hold up to quite a bit of power ! i have never seen a backplate for a 40 series however! but jackshafts and mounts are not that hard to do.
mysteryboy28
Lansing, MI
what about something like this http://www.google.com/imgres?q=jack...8&start=43&ndsp=24&ved=1t:429,r:14,s:43,i:198
or something like this that would be easily installed and line up perfect
that little jackshaft setup is pretty bad-a$$ for $15. however that was the AUCTION PRICE of it, 2 years ago. good luck finding something similar in that price range!
i'd just bite the bullet and fabricate a simple jackshaft using a couple of 5/8" pillow block bearings, a 5/8" shaft (about 10 inches long) with 3/16" keyway (i carved out my own keyway with a grinder. lol), a couple of sprockets, 4 bolts, done. that's assuming that your driven pulley is 5/8" inner diameter. if it's 3/4", then do everything in 3/4". :)
mysteryboy28
Lansing, MI
I have found this but do you think the engine would bolt up to it and work with the 3/4 40 serious
http://www.bmikarts.com/item/Motor-Mount-Plate-with-Jackshaft-and-Bearings-400361-6636
serious? what's with "serious"? lol. did you mean series? comet 40 series?
make sure you have the right diameter shaft for your driven pulley and sprocket(s). 3/4" and 5/8" are both very common.
that setup from BMI looks pretty bulky, and you'll be limited as to where you can put it. i'd think you'd be better off making your own jackshaft using pillow block bearings (less than $10 each on eBay).
anderkart
Surprise Arizona USA
JBkartman
how would you mount the pillow block bearings though on my kart? I would say those would be a good idea but complicated to mount and making sure it lines up. decisions decisions :huh::stir:
mysteryboy28
Lansing, MI
tape measure and a drill is all you need to mount the pillow blocks and have them align properly. drill small holes for the bolts first (like 1/8") to get them centered where you want the holes. then widen the holes with the proper size drillbit (3/8"?).
here's the one i made:
JBkartman
thanks anderkart if that bracket works then thats probably the route id go with because it doesnt require much lol. Do you think the distance from the drive and driven will be at a far enough distance?
anderkart
I'd expect the jackshaft box in my ebay link has those same 8 motormount holes drilled through the bottom side, just like the top has. If so, it should just bolt right on between your engine and old motor mount. You could email that seller asking if the bottom side has 8 holes just like the top.
