Been a week or so since posting, but here is where we are.
1. got the engine running pretty good - the 6hp Tecumseh, had to pull the carb back apart and reclean the passages, clean out the tiny little passages in both the mixtue screws, but the engine runs and idles now.
2. Still need a wheel, it is definately a bent wheel, as the wobble moves with the wheel.
3. Need a jackshaft sprocket, still trying to figure what # of teeth to get, anyone know the stock Manco Dingo jackshaft sprocket tooth count? I think it is 12, and I am not sure if 10 or 14 or anywhere in between is going to make that much difference. Once I get the sprocket, I will put the TC on the kart. right now it is running a Clutch with a 12 tooth gear and a 72 tooth sprocket on the axle.
4. A buddy welded up the bad spots, but I have not yet purchased the pipe for a roll cage, don't have a pipe bender, and will have to borrow my buddies mig when I do get this ready.
The kart runs as is and best guess is it achieves around 25 mph, and maybe a little more with the kid on it. the wheel wobble makes me nervous, and I am going to have to find a 9.5-8 steel rim with a keyed 1" bore soon. We are also going to have to get new front tires soon.
Now, tomorrow, i am going to look at 2 other karts - one is a 5hp motor that runs, needs the brakes worked out, but it is an old style. the second supposedly runs, but needs a clutch, this one is interesting as it appears from the pics to be running on a vertical shaft motor. I can buy either for around $100, so I am going to look at both and go from there. I am thinking the first one, as the current owner has the brake parts, but cant figure out how to make it work, says he will start and run the kart for me, and has a "spare" set of tires that goes with it, maybe he will have the rim I need as well. I have seen a lot of karts with the 18" tires and 9.5-8 wheels, but can't seem to find where to buy one. Still looking......
That is the current status, maybe this weekend we will take the cart out to the trails and I will let the kid take some videos while riding it.
talk to you later.
d
