new guy with new toy for the kid
anderkart
Surprise Arizona USA
Sounds like your sneaking up on getting that 6hp dialed in.
I remember reading that some round Tecumseh float bowls will fit on in any position but only work well in one certain position.
Hey any chance your carbs adjustment screws are just missing their tension-ing springs?
webrx
Anderkart, exactly right, I just went and looked and no spring on the adjusting screw. Any idea where I am gonna get one of those ;)
d
anderkart
If you dont have a mower shop nearby, I'll bet you'd find a suitable spring at a good hardware store. You could always stretch/cut diferent springs to mod-em as necessary. Even if the spring had too large of a bore you could probably just slip a flat washer on first... All its gotta do is hold a little tension.
webrx
I have 3 motors, gonna look today and see if the little one, that does not get spark yet, has a spring, if not, then there is a mower shop in town I can run by on the way home.
d
webrx
Got the clutch on, and the chain, got the cart running, and zipped it down the road once tonight. gonna wait for daylight to do anymore, the carb adjust screw seated on me while coming back so throttle was very sluggish. I did get a compression spring from True Value today, and cut it and put it on, but by then it was 9:45 and we did not want to make any more noise as our neighbors have little ones.
I also replaced the stock sprocket with a 72 tooth #35 chain sprocket, and the cart seemed to do ok for speed, once the sluggish carb was overcome. gonna get the boy on it in the dirt tomorrow and see how he does.
One thing I found, was the left side of the axle seems to be bent, pretty good wobble while on the jack stands, gonna have to figure out if that can be straightened or will have to replace it eventually. It could be the rim, when I got the Kart the left tire was off the rim and I had to strap it down to get it to take a seal again, so a bent rim is a possibility, but I fear the worst.
d
webrx
OK, looks like I have a bent rim, I moved the tires from side to side and the wobble goes with the tire and rim. did a search online but can't find a replacment wheel tires say 18x9.50-8 so I think this means an 18 inch tire on a 9.50 inch wheel that is 8 inches wide. any idea where I can find one of these?
d
anderkart
d
18x9.50-8 means:
18" tall
9.50 wide
8" rim diameter
You might be able to straiten that rim... or possibly make it worse trying ;)
We could probably help ya track down a decent price on a new rim. We'd just need to know the bolt pattern and width.
bighead
Pacific Northwest USA
I think the Dingos have that octogon axle. The hub is part of the wheel. (I think)
So he needs a wheel that has the hub and wheel as one.
Sorry if I am wrong. I could be mixing them up with one of my old karts.
Is it like this wheel on my Dingo? No hub and octogon?
webrx
yep, single hole in the middle, not sure about octogon, but it is held on by a key and a single nut. I was thinking about trying to straighten it, maybe put a level on the center hub, figure out where it is high, hit it with a board and sledge. Thoughts? I figure it has to be out of true on the hub, so, if I can straighten it some, while I look for a new one, it will make it a little more fun for the boy.
d
webrx
If I can't find the right wheels, is there a hub adapter made that will get me from the center bolt design of the dingo to a standard 4x4 go-kart wheel? I think I have a 1" live axle, but where the wheel goes on it appears to be reduced to 7/8" with a key.
OK. I think it is a live axle, because when i turn the sprocket both wheels turn with it and both wheels are locked with the axle with a key and keyway arrangement.
d
bighead
For $50 you need to go buy that kart. The roll bar alone is what you really need. Head rest as well.
Also check the style of axle. My dingo has an octogon axle. This CL kart may also.
webrx
unfortunately I am in Reno, NV not anywhere near elizabethville, Pa.
d
webrx
Yeah, bummer, if I was close I would have jumped on it.
In any case, if someone has a spare rim 9.50-8 for a dingo 7/8 shaft with key, please let me know.
d
webrx
I was talking to T-Man about how he modified his 7/8 hex axle to accomodate a 1" hub, and it appears he and I both came to a similar methodology for accomplishment. He has videos up that show what he did, me, not so lucky im afraid, no video, but I will try to explain what I was planning to do, and how I prototyped it.
First, the thought was to take a 7/8" round shaft (not hex as I apparently have an aftermarket live axle on my cart) and expand it to fit a 1" hub. Now, it turns out I don't need to do this, as I found out this evening (after finding my calipers) that I have a 1" shaft so it is indeed an aftermarket and I caught a break on this as 1" axle parts are much easier to find then 7/8 hex parts.
Now, I did find myself in a small predicament a while back, when my 6hp Tecumseh was not running well, and I had a functioning 3 hp B&S motor. the Centrifigual Clutch and the engine side of my two Comet TCs, both are 3/4 shaft. So, I went to True Value Hardware and bought a couple 5/8" id and 3/4" od bronze bushings, used a dremel to cut a 1/4 slot in the bushing (full length of the bushing) and slid these two bushings on the shaft alongside the keyway. Now, this won't hold with a standard key for a 5/8 (or 3/4 for that matter) key as there is just not enough key getting into both of the keyways. So, back to TV for a new "taller" key, and a little filing to fit, and there you have it, a way to fit a 3/4" centrifigul clutch to a 5/8 motor shaft. since the clutch has allen head retaining screws (one on the key and one offset about 90 degrees or so) the clutch seems to hold well and has no issues with being out of balance.
One note, you may have to use some emory cloth to take just a smidge off the outside of the bushing so it will fit on without having to pound everything together. Also, I ran a round wire brush on a drill inside the old clutch to remove any corrosion.test fit it all and make sure you can put it on and off without a hammer before committing, cause getting it off if you tap it on becomes a bit of a pain (but a finger type wheel puller will help if you get a little anxious)
You all probably knew how to do this already, and I will take a pic to show how I did it if you want, but it is actually a pretty easy concept, and with the bronze bushing in place, and a taller key, everything feels real solid.
Dave
webrx
I did not need to install longer set screws, as the one on the taller key was perfect and the 90 degree out one locks down on the bushing. The bushing can't spin because it is slotted to fit around the key.
Question: I am thinking about investing in a couple of these hubs to fit my axle
Steel Hub for 1" live axle. No step - Plated steel wheel hub with 1/4" keyway for 1" live axle. Lug nuts included. Bright zinc plated. Four bolts on a 4" circle. 1/2" - 20 x 1-1/4" welded bolts. 3-1/4" centered hub length. http://www.mfgsupply.com/m/c/53-681.html is the 4" circle what I want to have in order to find relatively inexpensive wheels to fit a kart. It seems like this is a pretty universal size - But want to be sure before investing in something that I may not be able to use.
Northern tool has one also for a couple bucks less but the description there says "Four-holes; 1 in. bore with 1/4 in. keyway. Use with our sprockets on live axles. Standard 2 13/16 in. bolt kart spacing" http://www.northerntool.com/shop/tools/product_52526_52526
Northern tool has been recommended and I want to get the right ones the first time.
d
anderkart
I'd price rims/tires + shipping costs before deciding.
I've ran across lots of nice used golf cart tires all mounted up on steel rims for sale really cheap on my local craigslist. (like $25 or $50 for a set of 4)
Most of these use that same 4 on 4" bolt pattern in your top link. The yuppies yank-em off their golf carts to install big off-road tires/rims and end up selling they're perfectly good old original set off for peanuts.
I'd try entering golf cart tires into your local craigslist search window and see if you can find any bargains near you.
Check out this ad I found here in phoenix for example: http://phoenix.craigslist.org/evl/rvs/2255867469.html
