Hey everybody, just got my first go kart.
I've always wanted one, but I don't know a whole lot about the little one cylinder engines. I've worked with larger car engines, but never with this small of an engine. To start off, it's a Murray Hard-Drive Go Kart with the 6hp Tecumseh engine. I managed to get it up and running a few days ago and was able to drive it around a little. Then today I tried to start it up but it wouldn't. The first few minutes it would run for a few seconds then die. I then got it finally running after about ten minutes but as soon as I touched the gas, it died. I got it started one more time but died again when I tried to move the throttle. Now it won't even start up at all now matter how much I try. I hadn't done anything to the engine itself since it was last running. The only difference between now and when it last ran is the temperature. It was about 45 or so the last time I had it running. It's a little below freezing now.I looked in the carb, but didn't see any buildup, so it should be getting gas, and it's also getting spark. I really don't know what the problem is so any suggestions would be appreciated.
Next question is about an engine swap. I'm thinking about using the engine, transmission, and differential from a mower. The mower I have is an Agco Allis 1716H lawnmower with a 16hp engine. Would the trans and diff from the mower stand up to the speeds of a go kart? Link to identical mower: http://www.fastline.com/v100/1996-A...ail-db81b10f-e3a6-4949-882a-b2f33bc0aaaf.aspx
Go kart pictures:
Go kart pictures:
