tacho
Hi all.... I have been lurking here for a while and decided to jump in and say g'day....
I recently acquired a second hand Arrow AX6 go kart from a friend. It is a rolling chassis (no motor) with a few minor missing parts. It has a 50mm rear axle (3 bearings) and is in reasonable shape... a bit dusty/dirty from sitting around for a long time.
I am planning to try a Lifan 4 stroke conversion, along the lines of this thread:
http://www.diygokarts.com/vb/showthread.php?t=9829
I read through the whole thread, only to discover Dan never completed the story and has not provided a summary of the completed project... did it work well? Speed? Acceleration? Etc...
I can get virtually the same engine as the above thread on E-bay (Australia) here: http://www.ebay.com.au/itm/291539479133?_trksid=p2060353.m1438.l2649&ssPageName=STRK:MEBIDX:IT
This one is "full auto" (wet clutch?), but there is also a semi-auto and/or a full manual version... Which is best? Any experience with these?
Some specs: 125cc 4 stroke, 8.5kw(11hp) max power @ 9500rpm, 6.5kw(8.7hp) rated power @7500rpm. Torque: at least 8.8 Nm @ 5,500 rpm
Before I start (and spent too much money), I have some questions and/or observations:
1. Is this a viable option?
2. What kind of performance: speed/acceleration can I expect (eg, compared to a standard K100 'J' or 'S' 2 stroke motor)?
3. I am an older, bigger guy (over 115kg / 250lbs): Is this going to have enough power to be a fun casual kart (no official racing)... Just doing some laps with friends.
4. Any suggestions for other engine options (limited budget)
5. I plan to use it both on bitumen and on dirt (changing to bigger wheels/tyres on dirt): It currently has 5" rims with 10" (F) and 11" (R) slicks on it... but I plan to run 6" rims with 12" or 13" dirt tyres on our gravel track, to give some more ground clearance...
In case you are interested, I'll be using it here: https://www.google.com.au/maps/@-33.5532807,118.1552233,303m/data=!3m1!1e3?hl=en
Dirt track (around the outside) is about 650m long... A couple of my mates have more expensive Go Karts (125cc water cooled 2 strokes) and currently do laps in around 40 seconds... but there are others running Yamaha K100J motors, that are only a little slower on this track.
I just wanna get out and have some (cheap) fun... not set new land speed records.
Anyway, thanks for reading.... any feedback appreciated.
- Tacho
- Tacho
to the forum!!!!
