New from Eastern, NC
Spudwrench72
Eastern, NC
Hi from Eastern,NC
I just got a Manco 13.5HP Go Kart. It's a Robin Subaru engine.
I took the carb of and cleaned it, put fresh gas in it, made sure cap was venting, new NGK-BP6ES PLUG, cleaned the air filter.
I have spark,air and fuel. I removed the plug and opened the choke pulled the cord 6 or 8 times to ensure no gas in the cylinder. It started once. Ran rough for bat 5 mins while I was trying to dail in the air/fuel mixture it cut off. I set the air/fuel back to 2 full turns out. It is not damage. I can't get it to start again. I went through the whole process listed above again. NO LUCK... DOES ANYONE HAVE ANY IDEALS OTHER THAN USEING IT FOR TARGET PRACTICE???? Please help
Poboy kartman
Senior Moments Member
White Settlement Texas
Sorry to say, but your carb is still dirty......
Probably trash in the tank re-fouled the carb....
Make sure all the passages are clear with a fine wire when recleaning, and that your float is good.
But before....
Just to be sure I'm right shoot some gas, carb or brake cleaner, or starting fluid in the carb throat and see if it runs for a few seconds....if not, let us know....and we'll look at plan B.
Spudwrench72
Eastern, NC
I'm from Wilmington, NC BUT live in WASHINGTON, NC
---------- Post added at 05:12 PM ---------- Previous post was at 05:03 PM ----------
OK, I done what Yall said. In was getting trash from the tank. Cleaned everything tried again. IT DID START!!! Ran for ant ten mins. Then ran out of gas. I put more in it. Could not get it to start again. Now it's not getting fire. WTF??? I thought shovel heads were temperamental.
Poboy kartman
You know what's tempermental nowadays ? Spark plugs! Don't ask me why....'cause IDK....but...cheap, easy place to start.... Try replacing it...you'd be surprised how often that's all it is....let us know.
