New build thoughts
Things to check...
Flywheel key. Timing might be off
Camshaft compression release. Might be stuck and not bumping the valve open.
Camshaft timing. - Make sure the dots on cam and crank gear align.
Valve lash. People always recommend checking valve lash. It is just a good reason to look in there, my valve lash has always been ok.
When starting, pull slowly until you feel the start of the compression stroke. Then let the cord retract. Then hold tight and give it a good pull. From what I've read and experienced, this problem often fixes itself, which is probably not the best solution. LOL
On the last engine, there was a while where I was getting kickbacks. Then I thought I had no compression for a bit. Then everything was ok. I did break a flywheel key at one point, but not sure it was related (or even at the same time as the kickback issues). This was all when the engine was just put together.
Everything has been fine since.
GoFast157
Update**
Almost finished with this bad boy
GoFast157
What did you paint it with?
I sprayed it with some Rustoleum Safety Orange mixed with Acetone and Enamel Hardner. It turned out pretty well. I probably should have added a little more hardner than I used. But overall impressed myself for first time using a paint sprayer.
Does anyone know if I can enter this into the build off contest? I started it last October.
josh7owens
I’m about to paint mine with the Rustoleum Safety blue. I need to look up how much hardener to use. I ordered some online but it hasn’t came in yet. I’m planning to paint this weekend.
