I ended up having to grind some relief on one of the reinforcement fins and part of one of the oil caps to get everything to fit. Tried to mount everything to the kart to discover that the tc wouldn't clear my engine mounting plate. Built a new plate this weekend and finally got everything mounted and I must say that I am impressed with the performance. However, with me driving, I can't reach maximum rpms on the engine. I'm thinking about adding a jackshaft which will actually benefit me in 2 ways.. one the obvious, even more torque and Less load on engine so I can get maximum rpms out of it.. Second, I really need my axle sprocket on the opposite side of the kart because it interferes with the caliper jack screw with the caliper mount I came up with this weekend.. I had to cut 1/2 of the bolt off to get it to fit.. moving the sprocket to the opposite side will allow me to use a full length bolt in the caliper if I can find one to replace the one I cut off. Anyone have any pics of their design of jackshaft that will allow moving the axle sprocket from the left side of the kart to the right side? Also, I've seen pictures of jackshafts welded in place, but shouldn't they be adjustable to be able to adjust chain tension?
