Need to know what brake fluid to use and need to bleed it..
lol....dang... ok...i gotta take everything apart crap.....
---------- Post added at 12:38 PM ---------- Previous post was at 12:37 PM ----------
lesson learned....dont ever let ur kart seat for untimely event of period....more money getting it to fix then having fun with jt..
That goes for any engine, vehicle, machine, .....
Use it or lose it.
Rail just said how to test...
The brakes shouldn't leak... There shouldn't be any movement on the machine with firm pressure of your foot... Aswell as the pedal shouldn't bottom out or go slowly down...
What's so confusing?
nghianevo
Chandler Arizona
well how can it be firm if it full of air.. lol im trying to see if my master cylinder build pressure..and so far...it doesnt...it did for a bit....but i didnt fill the master cylinder with the fluid so it iar again
..now i coulsnt get it to build pressure..
Dude... You have to work on your spelling and grammar... For the most part I can really understand that last post...
Rail rider
Inmate # 3192016
Planet earth ( the flat one)
Bleed the brakes again .. get all the air out . Get a brake bleeder from harbor freight... It's a few bucks I explained how to make one .
---------- Post added at 12:30 PM ---------- Previous post was at 12:23 PM ----------
I think he's a young Vietnamese kid. It takes tyme to learn a new language.
Tinkicker
Are you stupid, boy?
Alabama
Little helpful info on the fluid types:
DOT 3: most common fluid in everything, attracts water
DOT 4: like a juiced-up DOT 3...higher temp boiling point, but totally compatible, attracts water
DOT 5: silicone-based, does not draw moisture, NOT compatible with ABS because it compresses more than DOT 3 & 4, messing with the ABS computer, but it won't hurt paint like the other two
