charlesnj6
- Messages
- 13
- Reaction score
- 0
my grandson has a rocketa go cart 110 cc three speed forward and reverse, well the problem was he forgot to keep a check on the oil level and it got a little bit to low and the wrist pin got stuck due to a lack of lubrication. I found that out after it quit running and would not turn over so i took the head and cylinder off and that's what i found. Luckilly it was not to severe and i was able to unstick it and put a little oil on it and it seems fine. Now i need to find out how to time the overhead chain driven valves, i cant find any marks on the gears however i did mark the camshaft gear and the camshaft hub but the crankshaft gear you can not get to it. I put it back together with the piston on TDC and both valves closed but afraid to start it up because i'am not sure I have it right, can anyone help me out on this?
