Need some advice for cleaning an old engine
M
mancodingouk
Guest
I have a Manco with a 5hp Briggs engine that is about 20 years old I reckon... and I bet its never been cleaned in that time either!
I've taken the engine off the frame and I'm in the middle of cleaning down the frame ready for some primer.
The bit I'm not so sure about tackling is how best to clean the engine. I'm not particularly mechanically minded, so I don't want to strip it down completely as I'll never get it back together. I've taken off the air filter and exhaust, and I was planning on cleaning them off in citirc acid to get rid of marks and rust etc.
How's best to clean the main body of the engine? I have some silver spray for the engine block, but I want to make sure I've used the best cleaning method before I spray it. Is it best to just pressure wash the engine? If anyone has any advice I'd appreciate it.
Thanks
r_chez_08
Should be in the shop...
Cornwall, UK
I would take off all external components. Carb, fuel tank etc.
Using a power washer you can clean off the engine. If you have an air compressor you can make a DIY soda blaster to clean as well. Degrease the block, maybe rub it down, then spray it, masking off anything that doesn't want spraying like the crank.
r97
Measure twice cut once
Massachusetts, USA
If you are looking into the home-brew soda blasting, make sure you have a very big compressor, and a crap load of baking soda. I kept borrowing neighbors compressors, but none were big enough. After a month or so of trying I rented a 5.5hp gasoline powered air compressor that pumped out 11cf/min max. That compressor did a decent job, although not perfect. I still had bits of factory clear coat, a previous owners paint job, and grime built up from 30 years of use. I will mention that this was a V-twin motorcycle engine, so a little flat head briggs wont be as much of a headache.
Feel free to try the home brew soda blaster, it's certainly worth a shot, but if I were to do my engine again I would pay someone to do it, or at least get proper equipment. Here is a link to the homemade soda blaster gun, http://www.aircooledtech.com/tools-on-the-cheap/soda_blaster/.
