Need parts for kartco kart 675
booniehoonie
I'm looking parts for a kartco kart 675 with a 3/4 keyed live axle I'm looking for the drive wheel set up. Or a hub that I can bolt it all up to the rim and tire. Its a project that I'm working on with my 9 year old son he's very excited to build his first go kart
booniehoonie
New to go karts. But what I meant to say is I'm looking for a sprocket that bolts to the brake drum and the the spindle hub. Because I just got a plain frame with no tires or wheels.
booniehoonie
Ok here are the pictures of the go kart.
Go Power Sports, BMI, Manufacturer’s Supply, Gokart Supply are just a few suppliers for parts. You can start there.
I see what you're thinking about now. The motor mount is so far to the left that the axle sprocket must be squeezed in between the band brake and the wheel, and it looks like there's not enough space to do separates there. Must be wanting a "sprocket drum" that is both axle sprocket and OD-machined brake drum. See if link below works for you. You will see those combo units, and also separate brake drums and sprockets made to bolt together, so you can change sprockets only (60-tooth, 72-tooth, etc.), and get a different gear ratio that way.
Search Results > sprocket drum (bmikarts.com)
booniehoonie
Thank y'all for the help with this cart. I just ordered the parts for it yesterday and when I get them in and installed on the go kart I'll post some pictures. Thanks
tgann2384
Bmikarts.com
booniehoonie
Thanks already ordered the parts from bmikarts and got them in yesterday here's some pics of it almost together it was red but he wanted it blue.
booniehoonie
I'm thinking about putting the new predator 224 on it from some of the reviews I've seen on it it's a off brand ducar engine
