need help with recoil,
kendelrk
redneck engineer
westland michigan
so i pulled the legs off ready for a nice cleaning, as soon as the last leg came off it all popped out and the spring hit me in the face, okay so thats over, i can wind the spring just fine, but im having a problem putting in the peice of the pull start it connects to, any ideas?
Russ2251
AZUSA:Powered by LAWN-BOY
Worst video I've seen to date.
Spray WD-40 into spring area...and a few drops of SAE 30 into hole in end of starter clutch.
No lubricant of any kind in ball/ratchet area. Must be absolutely dry and contaminant free.
kendelrk
redneck engineer
westland michigan
probablly, my camera dosent pick up well when its dark outside and im using the chimsey kitchen light that has 5 bulbs, and 2 work, and the whole spring and all is out, i cant get it back in right, i can get it wound, but not into the hole of the slot, could it be because the end isint bent?
osso12
Kartman
Mesquite Texas
the-cyborg, the ratchet is brand new, its only had about 15 minutes of use on it
Take a file, and go over the outer part of the crankshaft and file the end of the crankshaft. Put it back on, the squeel should stop.
You don't have to file much at all...Just go over it a couple times.
Its not going to hurt anything as your not removing that much metal, only the burrs.
South Kart3377
Kart designer
Va
Your luckeyer than me, on my 8hp flathead briggs You pull the rope and then if it dosen't start you spin the driven over clockwise and try again till' it starts.
kendelrk
redneck engineer
westland michigan
you may have it better than me right now, its apart in the kitchen with the spring and all the parts sitting there in peices,
kendelrk
redneck engineer
westland michigan
no, the kitchen table was my work place, because at 1 in the morning you cant be in the garage around here, my mom would probablly throw it at me and be like blahh blahh blahh tools in my kitchen blahh blahh blahh mess blah blah blah get out of here
osso12
Kartman
Mesquite Texas
n my mom would probablly throw it at me and be like blahh blahh blahh tools in my kitchen blahh blahh blahh mess blah blah blah get out of here
ok... substitute "Tools" above for "Go kart parts"
that was my point....
But, my whole house including living room, bed room and kitchen are reserved for Go kart parts and repairs... Good thing I own my own home!
kendelrk
redneck engineer
westland michigan
i dont, i love with my grandparents mom unkle little brother and dog, yeah, but thats all together and good now, now just got to fix my other problem and i should be riding away, is 10 tooth clutch to 54 tooth sprocket going to burn up clutch?
