So i have recently purchased a predator 212 engine for an old off road go-kart. At first it was running great and had no problems until I went through a couple shallow water puddles. Since then It has been idling with the choke closed as if it were opened but as soon as I open the choke to start riding, it stalls out. I have taken the carb apart and sprayed inside and out the main jet and the plastic jet located under the idle adjustment screw with carb cleaner. And it is still having the same issues. Please let me know if I have forgotten or skipped a step.
P.s. I have also recently added in fuel injector cleaner and changed the oil.
