need help with my clutch please
jbenitez
Missouri
So I got my new engine today its a predator 6.5hp 212cc and I tried putting my clutch on it but it will not slide all the way on the shaft. The key on the engine shaft stops it from sliding in all the way. There's about an inch left to go on the shaft that the clutch cant go in anymore. Clutch is brand new. Please help?!?!?
jbenitez
Missouri
Yeah I've tried it 3 times with no luck. The keyway on the clutch isn't very long so it hits the end on it and on the shaft the key is all the way to the back. So its like there's no way for it to slide further because the key is hitting already
jbenitez
Missouri
No but the little slot for the key isn't very long. So the key hits the end of the slot on the clutch and hits the shaft slot as well. The clutch isn't supposed to have the key slot all the way through is it? I feel like if it was all the way then the clutch would slide all the way on the shaft without the key hitting the end
jbenitez
Missouri
Hmm ill try that. Because I tried to use the key that came with the clutch and put it on the shaft but then it started grinding and smoking when I gave it some gas.
2SlickNick
American Minibikes @ FB
Mesa, AZ.
:useless:
My clutch has a built in key....
But again:useless:
Sounds as if you have a wrong something or tapered something.
This is not a key problem. Thekey would not have made the clutch grind and smoke. This sounds more like a gear ratio issue, where the clutch is working too hard and is slipping. What is the tooth count on the clutch as well as the axle sprocket. Please also give us the tyre diameter. This will help us troubleshoot your problem better.
Oh, and :useless:
jbenitez
Missouri
It slides all the way back if I use the key that came with the clutch. Its about 1/4 of the size in length of the key that came with the motor but it starts grinding and smoking. Like the engine shaft is spinning inside the clutch
jbenitez
Missouri
Yesterday when I had it running with the key that came with the clutch I noticed small sparks were coming off as I would press the gas.
jbenitez
Missouri
I'm new to this go kart stuff. I bought it from a guy but I wanted to get a new motor for it since the last one was leaking oil bad.
