The hardest part is posting pictures and you've got that!!!!
Have you removed all the set screws that you can see?
Take out the setscrews if any, then get some heat on it.... keep the torch moving..... also need a puller(it looks like someone used that but no heat... hence why it broke)(I know BC I speak from experience...)
That is what a pulley is.... for a belt.......
Can you weld a large nut on the pulley and use a bolt to get the pulley off the shaft.
I assume you tried the usual methods and it is rusted in place or something.
So heat and puller? I don't have any gas left for my blowtorch but is a trimmed lighter enough? (Sounds stupid)
---------- Post added at 01:05 PM ---------- Previous post was at 01:03 PM ----------
Yes! I can do that. Thank you guys so much!!
If you search youtube, you will find a bunch of videos.
Seems to be a common problem.
I got it off! Oil n Rubberhammer! Thanks again, i know where to ask for help from now on!![]()
Heat it up spray it with some PB blaster and let it soak over night. Autozone or orielys should have a pulley puller you can rent for free.
Ok, so put the broken one back on and lets try some of these other methods.
Glad to hear you got it off.
https://www.youtube.com/watch?v=J88-RdWnNT0
Last one; Any website where i can buy cheap clutches and sprockets that fit this type of engine? I'd be glad to know!
I got one from GoPowersports...you need to measure the shaft size and show us what this is going on.
Edit: Oh wait...you haven't built it yet....DOH!!! Just let us know the shaft size.
It's here:I got one from GoPowersports...you need to measure the shaft size and show us what this is going on.
I don't have a conversion handy...just need the diameter in inches.
---------- Post added at 08:09 AM ---------- Previous post was at 08:01 AM ----------
Nevermind...found it...1".
Bad news...no cheap clutches for you.
Probably need a knock off TAV2 .
Since you're asking for parts....please fill out a profile location.
