Need help, don't know how to remove a belt/strap sprocket
ulrikwilmann
Norway
Hey, i'm new to these type of engines and i'm going to build a gokart soon, but i don't know how to remove this crankshaft. Last owner broke it up so i have to remove it.
I'm struggling to build a gokart, i do know how to weld but engines is hard for me
Appreciate help :wai:
The hardest part is posting pictures and you got that on post 1!!!!
Have you removed all the set screws that you can see?
Is it called a pulley?
ulrikwilmann
Norway
The hardest part is posting pictures and you've got that!!!!
Yep, both two of them!
I don't know if it's a pulley, it's supposed to be a strap or belt on there. It's a tecumseh hm80 1985 model. 8 hp
Hahah i can imagine, this is a oldschool forum but i figured out how to smack a photo in here :wai:
Take out the setscrews if any, then get some heat on it.... keep the torch moving..... also need a puller(it looks like someone used that but no heat... hence why it broke)(I know BC I speak from experience...)
That is what a pulley is.... for a belt.......
ulrikwilmann
Norway
So heat and puller? I don't have any gas left for my blowtorch but is a trimmed lighter enough? (Sounds stupid)
---------- Post added at 01:05 PM ---------- Previous post was at 01:03 PM ----------
Can you weld a large nut on the pulley and use a bolt to get the pulley off the shaft.
I assume you tried the usual methods and it is rusted in place or something.
Yes! I can do that. Thank you guys so much!!
If you search youtube, you will find a bunch of videos.
"Small engine pulley removal"
"Lawnmower stuck pulley"
Seems to be a common problem.
Jfive
Great falls Montana
Heat it up spray it with some PB blaster and let it soak over night. Autozone or orielys should have a pulley puller you can rent for free.
Staff Murderator
I got it off! Oil n Rubberhammer! Thanks again, i know where to ask for help from now on! :wai:
Excellent! Thanks for posting your success because now we have thread closure for the issue at hand. Most folks write about a problem but most are never resolved--at least that we know about.
If he keeps trying to remove the pulley after it's been removed, we've got issues. :D
However, for the sake of posterity that is indeed the best first course of action.
Last one; Any website where i can buy cheap clutches and sprockets that fit this type of engine? I'd be glad to know!
I got one from GoPowersports...you need to measure the shaft size and show us what this is going on.
Edit: Oh wait...you haven't built it yet....DOH!!! Just let us know the shaft size.
ulrikwilmann
Norway
http://m.ebay.com/itm/281876916308 is this one OK? Centrifugal clutch? Is it a clutch that goes off when you throttle/accelerate?
---------- Post added at 06:50 AM ---------- Previous post was at 06:47 AM ----------
Yeah sure man, i'll go out and check! I can upload a picture of the chassis aswell
---------- Post added at 06:58 AM ---------- Previous post was at 06:50 AM ----------
It's here:
Lenght = 7.5
Width = 2.5
I don't have a conversion handy...just need the diameter in inches.
---------- Post added at 08:09 AM ---------- Previous post was at 08:01 AM ----------
Nevermind...found it...1".
Bad news...no cheap clutches for you.
Probably need a knock off TAV2 .
Since you're asking for parts....please fill out a profile location.
ulrikwilmann
Norway
It's filled up, and thanks for help! I'll probably figure out some way to get a clutch.
They're out there...but expect @ $100 USD. A TAV 2 knock-off is around $80 ....but you'll get extra gearing and much better performance.
The clutch you linked was for a 3/4" shaft.
