I want to start a pretty "different" type of project, instead of the go kart that I was going to build. I want to buy a mobility scooter (http://www.easymobilityco.com/ctm_hs-580_mobility_scooter.htm) and add either an electric or gas engine.
I want it to go 40-50mph. I cannot sacrifice speed.
Here are some of my concerns...
Which would be cheaper (gas or electric?) Which would be cheaper to run/maintain? About how much would each cost, to get it to go that fast? Which would be easier to build?
Can you guys suggest me what engine I should use? Would this work, if I use gas? It's a 16hp 4 stroke. http://www.maxtool.com/us/products/XP16HPE.asp
Lastly, do you think it would be possible to somehow register this as a custom vehicle for local use (small streets and neighborhoods only)? I live in California. What would I have to add to this to make that possible, or is it just too much to be possible? I'm fine if this isn't possible, it would just be cool if it was. Cheap and easy transportation
Thanks.
Thanks.
