need go kart assistance
xhebrailduka
If anyone has facebook messenger plz let me know so i can show you a video of my go kart and what is going on with it it has to do with the clutch i posted earlier and got many great replies but i think if i send you a video on messenger it would be easier to understand the problem
xhebrailduka
Ok i posted it previously you responded too but im almost positive it would be much easier if i show it on video its the same problwm i mentioned earlier with rhe clutch i got a different answer from my uncle and from many other people i just want to know whatbit is i have to change i dont want to have to buy a new clutch for nothing or a sprocket if i dont need it
---------- Post added at 05:46 PM ---------- Previous post was at 05:45 PM ----------
If i post a video on youtube can i send yous a link?
lastgear
RED-LINE
Texas
I recently had the same problem, I took my clutch off and disassembled it. What i found was an broken spring. which was allowing the clutch to engage at very low RPMS..
MTNSleder
😈 Snake ƘƖԼԼЄ&
USA/CANADA
Take the clutch apart, take a few pictures then report back ;)
Were did you buy this clutch? Possible it's just a crappy brand of clutch...
That clutch and engine sounds HORRIBLE. What a terrible din!
What did you do to it?
Lasted two days, aye? Should last several years if used correctly.
... if it's improperly installed, driven in abusive conditions (sand, steep terrain, excessive weight in the kart or rear tires taller than 15"), the clutch might only last 20 minutes.
^ From my favorite clutch article ^
http://www.bmikarts.com/10-Things-to-Know-about-a-Centrifugal-Clutch_ep_63-1.html
xhebrailduka
The engine sounds great now i tghtened the black screw under the csrb and then it started up perfect all of the sudden but now my only problem is the clutch taking it out is a pain too i wasnt able to yesterday i gotta ask my uncle for some help
