JTSpeedDemon
Ok, wow, here's a real problem for you guys!
So the standard Raptor rod's oil clearance checked out at 0.002", so that's done. And I cleaned up the cylinder.
Now there's another problem. *facepalm*
You may remember it would mysteriously turn almost 2 whole revolutions and then lock. When I turned it the other way, it would unlock.
That was when the piston/con rod were still not installed, but the sidecover was.
Now it's STILL happening!!! I thought it was the governor gear, but I already pulled it. I also fiddled with the governor arm to make sure it wasn't interfering. No difference.
It always locks near the bottom of the compression stroke, and it locks hard enough that if I try to keep turning it, it just tips the block.
With the sidecover off, it spins nice and freely. It locks once the sidecover gets onto the dowel pins and the crank and cam bearing surfaces. The crank and cam both move up slightly when this happens, and once that all happens, it locks.
Nothing is contacting in the crankcase, that's not the problem.
I'm completely at a loss what to do.
HELP!!
HELP!!
