My Trike build
dcook3333
Dean
Pittsburgh, PA
I agree, nice job!
I do think you are going to be very dissapointed with the way it steers. Maybe consider going one wheel drive or springing $ for a differential. Though those comet diffs may be more than you want to sink into it.
Cotmullion
Mechanical nut
I agree, nice job!
I know, the steering is hard even wheeling it around the workshop!!
Cotmullion
Mechanical nut
Chain drive done, need to get throttle hooked up now, and brakes.
Blazkowiez
Kart Aficionado
Houston, Texas
I like what you're doing so far, I really do look forward to seeing how this deal handles.... live axle and that front end will be very very interesting to see the outcome.
Cotmullion
Mechanical nut
Got the frame painted, and re assembed today.
Cotmullion
Mechanical nut
Drive set up now, engine cowl painted, engine back on and running again too.
Cotmullion
Mechanical nut
Not too bad for vibration, definately feel it through your arse though :D
Managed a little throttle cable set up, not sure if I'll keep it. It depends whether I can think of a better design, but it does work alright. made it out of a bicycle front brake, as you may be able to tell.
Cotmullion
Mechanical nut
I have done some test runs now. It goes quite well, and after tweaking the choke, throttle and governer paddle it now doesn't seem so underpowered. I think it seemed underpowered before because it as not opening the throttle anywhere close to full.
Cotmullion
Mechanical nut
I have been working on the brakes this afternoon, although haven't got any photos to show yet. It is basically a big scrub brake on the right tire, which obviously would stop both wheels because it is live axle. I may well put a bicycle front brake on it too though.
Cotmullion
Mechanical nut
Heres the brake. It works well enough to lock both rears up, so I think it is adequete.
