My snowmobile kart project
Dang
New York
Anyone figure out what kind of engine it is? All i know its a 340 snowmobile engine and if i know more specific, like the brand i can look for parts for it.
jr dragster T
Cold place
Haha thanks for the heads up. I will make sure I pick one up when Im out. I pretty much spend my time playing with my new traxxas t-maxx that I got lately haven't had a chance to work on the gokart. I wreck my t-maxx other day so gonna purchase parts for it and in the meantime work on the gokart.
YAY for rc's. Although the T-MAXX 3.3 has some issues. sorry for the off topic post
Dang
New York
haha i got the 3.3 4908 model got one the good batch. i havent had a problem except when i wreck it and twisted my aluminum plate and broke the arm and shocks suspension lol.
MDMike
Toms River, NJ
a quick note about the tire fix,
The plugs in the kit are not designed to be burnt off.
Get a kit that has self vulcanitizing plugs, they won't come out even in a car doing burns out!
(and cut the plug thats left hanging out of the tire)
Dang
New York
I finally have time to work on it, if anyone can help me find a picture of the similar engine i have and help me find parts for it. I am in need of a air filter. All i know is the engine is a 340 sled and has Tillotson on it. I search but couldnt find much. I found 2 plugs but have no idea what its for, one is a round plug with 2 wire on the back a yellow and black color. The other plug is square looking with 3 wire 2 yellow color and a loose brown wire,the plug wire lead to the pull start. So if anyone can tell me what these are for and how to connect them, it did come with neon lights but not connected anymore so i assume one of the plug wire is maybe the generator to power the lights but i have no idea how to connect it or which plug, help me out guys.thanks
euge
i was thinking of building something like this once i get more experienced
Dang
New York
ok i am havin trouble figuring out which one to connect the the gas line there is 2 insert on the carburetor that stick out for a line. There is a silver one on top and a black on on the bottom which one connect to the gas?I assume the other one is for the oil line... I have a picture that circle it to identify.
Dang
New York
Upper is fuel lower is vacuum, there should be a hookup on the engine itself for the vac line. You have to premix the gas, I would run 25:1.
wats the purpose of the vac line for? I cant find any other hooked up dont even know exactly where is located.
Kenny_McCormic
Kartless....
Michigan Troll
It operates the carb, there should be a barb on the intake manifold or crankcase for the vacuum pulse. I suppose in a pinch you could stick a hose on it and hyperventilate into the line.
Dang
New York
sorry man i dont have a good eye to spot so here some pictures and if u can show where its at.thanks
Dang
New York
you said the top silver piece was gas line so i connect it and the bottom black was vacuum line gas start pourin out of it......
ed1380
Banned
ATL, GA
i think the bottom might be a fuel return line although i dont see why it would need one. or bottom is vacuum line and the diaphragm is bad
Dang
New York
i notice when i connect the fuel line through that piece mention engine didnt startup on pull but when i pour a little gas in that place in the picture the engine startup with alot of smoke.
Dang
New York
right now i am jus stuck been workin on it all day still havent figure out where to connect the the fuel line to, if i connect the bottom piece the top piece squirt gas out and same goes if i connect the top the bottom piece gas come out. I wasted alot of gas so far so anyone know a fix?
Russ2251
AZUSA:Powered by LAWN-BOY
Proper connections are indicated in pic.
Carb not identical to yours but is basically the same.
I use these almost exclusively on all my 2 cycles.
May have torn diaphragm/stuck needle.
Get the kit and meticulously clean guts before re-assembly.
Get a better camera. Very hard to tell what you have.
