My go kart wont go!?
devino246
Official DIYGK Chem Nerd
Lynchburg, VA
Can someone reply to my please help post
Umm:
You gotta have a key between the sprocket and the axle
your sprocket appears to be to big
:mad2:
Dont run your kart with the sprocket like that. Its slowly wearing down the axle and sprocket hub.
r_chez_08
Should be in the shop...
Cornwall, UK
Ah just about to say that Devino, but you typed whilst i was watching the vids :)
Another thing is how many teeth are there on the clutch sprocket and the axle sprocket and how big are the wheels? I think when you put that key in and try to rev to go you will still not go due to a bad gear ratio.
karl
North east Ohio
I see 2 problems. The chain is not the right size and is not meshing on the clutch right. Also the rear sprocket needs to be bigger.
Good eye, Karl- The chain and axle sprocket are not the same pitch as the clutch. If I had to guess, I'd say the clutch is a #35, and the chain and axle sprocket are #40.
the-cyborg
Spring, Texas
Man this may be a dumb question....well maby two
but did you put keys at your wheel hubs ?
and whats that flopping around on your axle next to the sprocket a brake disk ? oh and yes you either need to get a #40 pitch clutch or a #35 sprocket and chain,
looking at your video close it looks as though your axle is turning, at least some but your wheels aren't as if there is no key and just free wheeling.
braydykart
i will have to buy a #35 chain and sprocket... the clutch i have is #35.
the thing flopping around i don't even know what it is. like i said in my first post i received this from someone, and it came with everything on it, missing a few big parts tho. I thought it was a holder for the sprocket, but im not sure. i will try and buy the #35 parts and see if that is the problem, thanks guys. but im still unsure on where to put this key that u guys are talking about?
braydykart
hey everyone this is the link where i bought my sprocket a while ago... it is #35 60 tooth sprocket... but it is quite big and i dont know if it would fit on my go kart? :s
http://www.mfgsupply.com/GoMiniSproc...on_id=ebVEZxk4
i bought this clutch http://www.mfgsupply.com/m/c/SS1258.html
i bought this sprocket http://www.mfgsupply.com/m/c/4-9484.html
and my question is now do i buy the #35 chain and it should work???
this is the #35 chain im looking at is it the correct one? http://www.mfgsupply.com/m/c/11-384.html
r97
Measure twice cut once
Massachusetts, USA
as devino said, you need to attach your sprocket to the axle! a key is required (assuming you already have a key way in the axle and sprocket).
secondly, you need to change your gear ratio, big tires, cent clutch, 5hp, and small axle sprocket = ruined clutch.
EDIT: :oops: didn't see the second page...
r_chez_08
Cornwall, UK
The wheels on your kart look pretty big (can you tell us the diameter of the tyres?)
The ratio still may not be sufficient.
The thing on the axle floating around looks like the brake disc and should be mounted on a hub similar to the sprocket hub with a key, and put inbetween the brake caliper.
That chain is very long and woul be good for a few spares. You could buy shorter if you want tho.
You also need a master link.
