Ok, you want it to go faster you need to wrap your brain around this first fact.
You gonna have to buy that speed. It's not free.
First thing I think I see it looks like you have scrub brakes that press against the tires. If this is correct you are very limited to tire size without some serious brake mods. So do you have these brakes?
Which brings another question if you do have them. How fast are you willing to go with a certain type of brake setup?
Next thing to consider. RPM limitations on your engine. It's your call there but if you're stuck at a certain tire size your RPM will be a determining factor in overall top speed. Consider removing the governor and do it the right way if you haven't.
Performance upgrade to the engine. The number one best bang for your buck without getting deeply involved will be a Stage 1 kit. If you can do normal routine engine work you can most likely handle this upgrade. It goes very well with a governor removal and an 18lb valve spring install.
Contrary to popular internet buffoonery you can do this and run your engine in the configuration above without installing a billet rod and flywheel. You just need to keep the engine under load and not run it wide open for extended periods or at all without having a load on it. It's when you start camming these things up and they start being able to pump air is when you really gotta do something with the rod...then it can make enough RPM under load to sling the flywheel apart.
Let's talk about clutches. I personally like a torque converter. But with a one wheel peel your sprocket is gonna usually be located right against the wheel and tire so that's gonna be a space issue not to mention those scrub brakes. Your tires have to stay lined up with the brake paddle. So you're going to need a lot of modding to make a TAV2 fit and line up. Engine spacers and so on. But the torque benefits will be outstanding...oh wait... nevermind... you'll just melt the tire my bad...
Back to the clutch...most racers use them and they haul balls. But the ones they use aren't cheap yard kart clutches either.
Look into getting a quality unit with springs that you can swap out to change your engagement RPM so you can talor it to your engine and driving habits so as to not burn up the clutch and get good response.
These are all things you can do.
Personally I would start with the engine first. It is the heart of the Beast. It has to be able to put life to all the rest of it. If that doesn't work, nothing works.
---------- Post added at 11:22 AM ---------- Previous post was at 11:06 AM ----------
My bad... I have not been subjected to the technical specifications of his engine over and over again as I have someone else's flathead Briggs with the frame bending torque and a super pulse carb...
Sorry Bthompson224, I have been corrected sir!
He said in his thread in Engines and Clutches that it's a 50T.
From the looks of it, the tires are 12-13", I'd estimate.
So with about 4.1/1, with a stock 212 on a normal yard kart, it's just too hard on the clutch to go any higher.
---------- Post added at 10:29 AM ---------- Previous post was at 09:54 AM ----------
Incorrect.
Bthompson224's kart has the OHV Tejunkseh(nuthin' personal Bthompson224).
