ok, i like the way you have chosen to set this up. what have you decided on with the axle and mounting the sprocket/brake disc? what is your axle length?
yea no problem! thats a good length and the only thing else i wondered was if you found a way to mount the sprocket and brake disc
Yesterday afternoon, I dropped-by at the bearing shop and purchased 3 units of bearing. I only need 2 actually, however I better have 1 spare unit. This is normally I do in case I mistakenly spoilt it, I still have a second chance.
This evening, I should cut the outer race and take the inner race. I need the inner race to be used as my washer since it has the 2 screw on it. I just realized that I used quite a number of inner race here. It's cheaper and easy to be cut and modified as well.
I should put them back this weekend.
OOPS! it happens, hardened steel is a bugger to work on. Um, as to the assembly for your sprocket, i like it! and what may work for you is to take some 1/8 or 3mm, and place it between your washers, weld it gently, but strongly! this will help give it the axial strength you are seeking. I looked for bits designed for hardened steels online, surprisingly they are hard to find... sigh. but i will keep looking.
To cut hardened steel with a drill bit, it must be a carbide bit, with a slow speed and lubricant. use moderate pressure and keep the part & bit cool.
http://drillbitwarehouse.com/index....&vmcchk=1&option=com_virtuemart&Itemid=600001 example
You could use a cobalt bit for drilling into hardened steel but just be careful because it will snap very easy and use plenty of coolant....
AHA! i forgot about cobalt! there are a few ones good for attacking hardened steels, think i could remember a single one? heck no! lol. Refresh my memory, why are you drilling the races? to put in bigger/more set screws?
