My clutch blew up
so the reason my clutch blew up was because the bushing was wobbling the clutch around? how much hp can a standard max torque clutch withstand? i am trying to find out why my clutch fell apart? could it have been the rpms i was fully pinned in high rpms when my clutch got damaged. also how much faster will my minibike go with a tav 2 vs a clutch. i was going at least 42 mph with the clutch with plenty of low end to hill climbs.
Clutches can pretty much handle a lot once they are locked up. I have a feeling that yours was a bit defective to begin with
Your clutch fell apart because something was wrong either with it, the installation, age, maintenance, something. I'm not sure of the max hp that a MaxTorque can take. I'm sure a Google search will reveal something. Keep in mind that there's usually an error margin, and the clutch will probably take more than the published spec, especially if gearing is appropriate. RPM is NOT a problem with a centrifugal clutch. Once the shoes are pinned to the drum, that's it. Nothing can "move too far" or anything.
All things being equal, you could easily go 10% faster with the TAV2, thanks to it's .90:1 overdrive (depending on how you gear it).
tundrabeagle3
Ca
I decided to buy another max torque clutch, the one I had came with a mini bike i bought off of craiglist. The clutch was stuck on the 5 hp briggs crank until, i took it off with a gear puller a few times. The c clips came off the clutch and made the bushing wobble. The new clutch ran like a champ i tested it today when i went for a long 3 hour ride today.
Well, there you go. No wonder the old one exploded. :roflol:
jamyers
Buffalo Gap, TX
A little bit of Anti-Seize, or even marine trailer wheel-bearing grease (WAY sticky stuff) is a good idea when putting anything on a crankshaft end.
Gear/Pulley Pullers are ok, but you've got to pull from behind OLY the part that's actually stuck on the shaft.
tundrabeagle3
Ca
A week into getting a new clutch, i noticed that the teeth were almost all the way ground down. What do you guys think happened?
jamyers
Buffalo Gap, TX
I'll bet the chain and clutch aren't the same pitch. I forget what pitch you've got, but it can be hard to determine which is which some times.
tundrabeagle3
Ca
I tried to return it and they wouldnt take it back, and i called max torque and they told me to buy another sprocket.so now im stuck
a new broken clutch :censored:. does anyone have an extra max torque clutch sprocket they can sell me? or anyone interested in buying a new clutch that needs a new sprocket?
tundrabeagle3
Ca
it was # 35 but the back sprocket looks pretty worn out and will need to be switched so im ok with either thanks.
tundrabeagle3
Ca
I think it was because the chain was on too tight. The guy that i bought the clutch from said it might have been because the chain was too loose.
jamyers
Buffalo Gap, TX
It'd have to be WAY too tight to eat the sprockets, wouldn't it? It'd have to be loose enough for it to be skipping teeth, which would wear them down...but surely you'd hear / feel that?
tundrabeagle3
Ca
It went through both of those scenarios i also had it fully pinned for long periods of time at over 5000 rpms (governor removed) and the chain was kinked up.
