mudduck7.3
, ford is the only way . the chevy body was free incase your wonderin why i used it. keep in mind the 44" dualies will only be on it when playing in bodies of water. just gonna run the set of four normally . still i know the motor will need some help to turn them but believe it or not the skid steer tires are heavier than the 44's . i know of a builder that claims he can make 85 hp out of my little briggs so i might go that route but im gonna see how she does first.the reduction through the entire drivetrain is 90:1 in forward low gear , 44:1 in forward hi gear and i didn't check reverse as reverse is normally the lowest gear . the axles will hold the tires fine just because the lack of power and weight that it would take to break them ..... now if it were on a truck with 44"s them axles would be toast.
theres a lot of trails and creeks by my house i will probly be taking it to test it and play now and again. but anyhow heres some pics bein as my internet is workin properly now
made a new steering column support and crossmember
the rear drive shaft installed
and some with the new rubber
i hate wires
