my 4x4 two cylinder turbo'd cart build
mudduck7.3
iowa
the front shocks im using are the front forks from a 70cc honda knock off dirtbike. they seem to fit the bill for now, definitley aren't too stiff and they felx out nice but im not sure i will keep them under there because they don't have as much travel as id like them to have. the rears will probly use the front forks from a 125cc dirtbike to help hold the extra weight of the engine.
Ugh. Install the shocks on an angle, and/or use bellcranks to soften them up. Adding weight hurts performance, and adding a car battery, well- ugh!
fowler
Bullsbrook West Aus
mer
it is a quick fix
and i have to face it i could remove weight from the back but it def needs more weight over the front end
that shock chioce sounds good by the way
mudduck7.3
iowa
i also like them because they add some good looks to the cart . they look very similar to the nitrogen shocks that some highend mud trucks and monstertrucks use
mudduck7.3
iowa
thanks! i did get the front suspension done today but i forgot the camera at home :mad2:. ill snap some pics tomarrow of it though . i will be starting into the rear suspension tomarrow and maybe fitting the yokes to the transfer case and the driveline brake mount for the brake caliper.
mudduck7.3
iowa
ok heres the update . ive got a lot done in the last two days but kept forgetting my camera at home . i got the yokes and the driveline disk brake mounted on the transfer case, i stretched the frame 6 inch's right by the gas and brake pedal for more leg room , cut and bent the shifter to where im comfortable shifting it while driving , built the rear suspension and have some coil springs in the rear for now until i find some more dirtbike forks to replace them. i also built some support brackets for the two link mounts on the frame. heres the pics:
front and rear suspension all in place ( still need to make track bars and the suspension is done)
front output of the transfer case with the disk brake mouted ( still need to make a bracket to hold the caliper in place)
rear output of the transfer case and the newly bent shifter
the supports i made for the two link mounts on the frame
I know I've expressed my power concerns, and you'll cross that bridge when you get there. But I do have to say that with that aside, this really is a cool project! As I'm sure you can tell by my screen name, I've got an affinity for all things four-by. What this equated to in my mind is an interesting scaled-down mudbogger or rockcrawling rig. I can't wait to see how this rig turns out!
mudduck7.3
iowa
thanks , i guess its a little obvious by my build on here that i share the same obsession with everything 4x4 :cheers2:. im always building new wheelin rigs just never any this small so its a little different.
i do have some pics of my trucks posted up in the off topic fun section titled "post your car" .
porsche930dude
Upstate, NY
haha thats nutz! dont listen to these guys that engine is plenty of power for this. I dunno about the turbo though. And i wouldnt weld the front diff
mudduck7.3
iowa
didnt get much done today as work ran later than normal. i added another crossmember to the frame to support the brake caliper bracket i made and added a support to the transfer case crossmemeber. i got some skidsteer tires on it for now ( they were free), they're 29 inches tall with no air in them but with seeing tires finally on it im thinkin i might go with a 27- 30 inch tire when its all said and done. but anyhow heres some pics. i also did some measuring on the body and i think im going to widen it between 4 and 6 inches. in the pics below the body is mocked up to be 4 inches wider than it originally was , i would like to hear some of you guy's thoughts on this as i don't want to go too wide with the body.
brake brackets and tcase support with the new crossmember
a first look at it with the tires and body
The Mechtician
Gargamel Jr.
Surrey, BC, Canada
Is that a Millermatic 250-something in the last pic? We use Millermatic 251's where I work, they're awesome machines :thumbsup: I could almost tell by your welds that you were using a Miller! Mine look very much the same. How old are you, mudduck?
mudduck7.3
iowa
right on the money with your guess. i always used lincoln welders when i went to school but i worked at musco sports lighting for a long time and all we used out there was 251 millermatics and they are really great machines. easy to tune and very trouble free.
im 21 ....... i know i know im a little too old for a gokart but im building this cart for my son so he can have somethin to wheel with till he gets old enough for the full size trucks, he's only 6 months old right now but i figure ill get to play with it for a few years before he can reach the pedals:wai:
