Murray Kilowatt model 60703X92C
Unbrokenhope
Roughneck
Near Abilene, tx
I was wondering if anyone could help me find a throttle cable for this cart, bought it last week and needed a little TLC. This is the last part I need so it will run like new. Parts are hard to fine since murray went bankrupt and B&S bought them...:mad2:
Any and all help is greatly appreciated! Would like to find a manual in paper or online form also.
Thanks,
RJ
Unbrokenhope
Roughneck
Near Abilene, tx
Well I thought we were on to something there but I can't seem to find it by the part number on there either...you would think there would be more info about these floating around the net somewhere. Thanks a lot, that is still a big help though!
Still looking for that elusive throttle cable
Unbrokenhope
Roughneck
Near Abilene, tx
I didn't even think about that...I had bout some throttle cable from the auto store but the sliding action is rough on it...bicycle cable would work perfect, any suggestions on the best place to find some?
If you are in the USA, Walmart should have it. Any bicycle shop should also have, but Walmart is probably your best bet.
You could always lube the inside of the outer cover of your auto store cable. It should help with the sliding action.
Unbrokenhope
Roughneck
Near Abilene, tx
I have lubed the cable that is on it...it is rideable like that until I get a better cable...gonna be awhile my wife have a wreck on her dads little four wheeler while we were playing today...gonna be a little while till I get back to all this
Unbrokenhope
Roughneck
Near Abilene, tx
2 sprained wrists, bruised collarbone, and some cuts and puncture wound on arms and hands. Could have been a lot worse, if she wouldnt have hit a tree it was a 20ft drop.... So thank god for trees!
LARRY MARSH
I have a murray kilowat go kart and the steering sector gear, the teeth are wore down causing it not to turn.
does anyone know where i could find this part, i have searched and searched, I know that murray does not make the go kart but somewhere I should be able to find it.
thanks.
thanks.
Start a thread of your own and post some pics of the part that is worn. We will be able to help you out when we see what the problem is. It will hopefully be an easy fix
