It's really not that much work if you own a welder and a good set of tools.
The hardest part is making the 90 degree mount.
You also need to fab up a new intake to orient the carb properly.
Then you need to make an oil dipper out of a small piece of plate, and bolt it to the rod. You have to be careful to mount it in such a way that it doesn't hit anything, but still gets close enough to the bottom of the sump to collect the oil.
The crankshaft PTO will be an odd size, so you either need an adapter, or you can run a belt tensioner clutch (pulleys are common for the mower shaft size).
If you can find lawnmowers and scrap metal for free all day long, then you'll have a nearly free engine.
