mounting vertical engines
Russ2251
AZUSA:Powered by LAWN-BOY
Engine will destroy itself in very short order unless highly modified to do so.
Not worth the effort considering what is readily available and usable as is.
Use the search button to find out more.
karl
North east Ohio
Yes it will get poor lubrication. You will haft to put an oil dipper on the connecting rod. If not the cam, crankshaft, and cylinder walls will get no oil. Also you have to tilt the carb.
studysession
CNC Guy
York, PA
Thanks -
Just sometimes I run across mowers with vertical shaft engines for really cheap and was hoping to use them.
slowcart
I been looking around on the race mower forums to see how they do it. It can be done with a peerless right angle gear box but will require some work to get it to work
newrider3
Colorado
It's really not that much work if you own a welder and a good set of tools.
The hardest part is making the 90 degree mount.
You also need to fab up a new intake to orient the carb properly.
Then you need to make an oil dipper out of a small piece of plate, and bolt it to the rod. You have to be careful to mount it in such a way that it doesn't hit anything, but still gets close enough to the bottom of the sump to collect the oil.
The crankshaft PTO will be an odd size, so you either need an adapter, or you can run a belt tensioner clutch (pulleys are common for the mower shaft size).
If you can find lawnmowers and scrap metal for free all day long, then you'll have a nearly free engine.
studysession
CNC Guy
York, PA
newrider3 -
That is what I was thinking but wasn't sure if any of that would hurt the engine?
People give away push mowers that work or can find them at yard sales for around $10 - 20.
