motor does not rev all the way out?
The Product
Willow Beach, Ontario
hey guys
wen i rev my motor out it doesn't seem to get to 3600 RPM's sounds like it hits maybe 2500 and sounds like it hits a rev limiter like a car like bounces off that RPM. isn't a governor supposed to keep it at a steady rev?:confused:
Rickracer
RM250 Race Kart Driver
Kissimmee Fl.
It's hard to say without seeing it, if it's a lean surge, you won't be able to see anything, but your spark plug will be very light grey to white. If it's a governor problem, you will see the governor arm moving in time with the surging. ;) :cool:
Kaptain Krunch
Pro Junk Collector
vermont
If its a lean surge, the governor should move with the surge also. Plug chop first, then check linkages. It very well could be a large burr in the main jet or something, chinese things are known to be less than perfect.
The Product
yea true enough my go kart will be runnin by the end of next week. im so excited!! its my first build!:D:D but yea the governor does move with the bouncing of the RPM but after i get it going ill check the spark plug
