More Power?
carter
So I have a go kart with a tecumseh HM100 engine in it. It also has a torque converter and differential. My question is, what upgrades can I do to make it faster? Acceleration would be my main focus here as I don't want to bypass my speed governor.
Change gearing slightly. What have you got now? Give us axle sprocket tooth count and TC sprocket tooth count
carter
10T teeth on the jackshaft 55 on the Differential 7.5" driven on the torque converter. I don't think I can change the sprocket on the differential, so I'm thinking I'll either need a bigger driven(do they make those?) or a smaller JS sprocket(do they make these?). Those are the things about the gearing.
As far as engine performance itself goes, I ride in a fairly dusty area so the less constricting air filter might not be the best idea. Do you know where I could get the flange(proper term?) to attach a pipe to, or are there specific things that need to go in a muffler, and if so, where can I find something that can do that?
Do you have a Peerless 100 differential? I installed one on my kids' kart, and successfully installed an altered sprocket on it. Perhaps I can step you through how I did it.
carter
I honestly don't know what I have, it came from factory with it I'm pretty sure and the thing is so caked with mud that I don't even know where to begin looking.
carter
2)
3)
4)
5)
pictures in order(wasn't sure what you wanted)
1)exhaust flange
2)jackshaft
3)jackshaft further away
4)torque converter close up
5)chain/sprockets close up
Even if it was easy enough to change the axle sprocket, there's not a lot of space there but, IMO, 5.5:1 should be ok with a cvt.
I'd start with exenos' idea of hi flow filter & exhaust
Nope- Not a Peerless 100. Pity.
If it were me, I'd consider getting rid of the diff-equipped axle, and replacing it with a live axle. The traction benefits are great, and it opens it up for re-gearing.
What size are the tires?
carter
Tires are 18x9.5x8 in the rear and 16x6x8 in the front. For the high flow filter and exhaust, Would there be a filter I could get that wouldn't compromise protection but still optimize flow? My back yard is literally powder in the areas where I've worn through the grass, which is alot. And do you know where I could get a flange to fit that exhaust or should I just try to make my own?
FatCat
2 stroke Addict!
Ottawa, IL
Great question! Say no to K+N! The proper way to open up the intake side is to use a good quality filter. Just use a larger one. I recommend Uni filters. By adding a larger filter more air can move through it while it's still doing a good job of filtering the air. K+N? They just remove filter material until they get their desired flow. :roflol:
carter
Would the way my filter mounts be a problem?
I use these deals because they are all that fit, and it has like a little black cover that goes over it and then that is all held on through a screw that goes through the middle. Would I maybe be able to find a one that is longer so I have more surface area?
FatCat
2 stroke Addict!
Ottawa, IL
I think you'll need to find an adapter to go to a round style foam filter. Im not sure where but I've seen these. Then you could use a taller round filter. I believe Uni makes custom foam filters I'd you wanted to go that route. You'll probably end up getting rid of the filter box setup. I don't see how you could make any other filter work with it.
carter
To make the flange for the exhaust, does it have to b any specific kind of metal of will any work? because I have a piece of metal that is the perfect thickness sitting in my garage and I'd be willing to machine this thing if need be.
Mild steel, at least 1/8" thick. Thicker would be better.
carter
Sorry for the double post, BUt I just remembered that there is also what I believe is a breather under the opening for the carb, they share this air filter. The **** thing has always fouled up my air filters with oil too. When I run a new intake, should I do one with the breather and the carb intake together again or separate? Or does it even matter?
If your PCV system is bleeding oil, first check to make sure crankcase is not overfull. There is such thing as too much oil. PCV valve may be bad.
No, you don't need to route that breather tube to your new air filter. Best thing to do is route it up high and out of the way somewhere, and just stick an automotive inline fuel filter on the end of the hose.
