So I have a go kart with a tecumseh HM100 engine in it. It also has a torque converter and differential. My question is, what upgrades can I do to make it faster? Acceleration would be my main focus here as I don't want to bypass my speed governor.
Tires are 18x9.5x8 in the rear and 16x6x8 in the front. For the high flow filter and exhaust, Would there be a filter I could get that wouldn't compromise protection but still optimize flow? My back yard is literally powder in the areas where I've worn through the grass, which is alot. And do you know where I could get a flange to fit that exhaust or should I just try to make my own?
Would the way my filter mounts be a problem?
I use these deals because they are all that fit, and it has like a little black cover that goes over it and then that is all held on through a screw that goes through the middle. Would I maybe be able to find a one that is longer so I have more surface area?![]()
To make the flange for the exhaust, does it have to b any specific kind of metal of will any work? because I have a piece of metal that is the perfect thickness sitting in my garage and I'd be willing to machine this thing if need be.
Alright cool, it's 1/8 jus t like what was already on there.Mild steel, at least 1/8" thick. Thicker would be better.
