minibike
r_chez_08
Should be in the shop...
Cornwall, UK
pics :)
some of my megga shiny (1000 grit emery paper) pully, the lathe i have been using, and part of my school workshops.
My bike progress pics will come tomorrow :)hoping to get her running in half term.
r_chez_08
Cornwall, UK
Pics of the bike :D
KieranM
Doin It!!
Kilkenny, Ireland
nice, looks a bit big for the engine (size of frame), For your steering, i cant see those bearings at their full potential, might just be the way im looking at it. Loving the wheel
r_chez_08
Cornwall, UK
Yeah the engine is kinda small, but I'll see how it goes. It's a 2.2hp g100 (they make a 2.5, but why don't I have it :( :L ) the bearing outer touches the plate holding the forks. The inner touches the tube that the bolt goes through. The bolt moves with the plate, and the whole system feels smooth. How would you reccomend doing it? The wheel works well, but is a little small. Thanks for your comments :)
r_chez_08
Cornwall, UK
Thanks. The bearings and throttle control came today.
The kart was made from my own plans inspired by the go kart guru plans.
r_chez_08
Cornwall, UK
Ok, glad you like it :D
I am on my half term soon, so hopefully I will weld the engine mount on, and paint her up. I still have loads if machining to do unfortunately, such as another pulley, the jackshaft, and the rest of the hub that mounts on to the wheel. Hope to finish her by Christmas :).
r_chez_08
Cornwall, UK
hi guys
right where was i? (for anyone reading this in the futre, the forum lost some data :))
i have painted up the frame, installed an engine mount, and got her pretty much working, apart from the engine doesnt idle, it will only start at high revs, and if you let the revs down it dies!!! i have cleaned the main jet in the carb.
i have also started to make a mudguard, as you can see from the pics everything gets a bit pooey, and crap is getting fired into the air filter.
i have also got the pictures for... umm the member i cannot remember the name of. Sorry!
the wheel is held on by a 16mm bolt, and the bolt goes through two 16mm i/d sleeves welded to the frame.
the steering and forks are again attached by a 16mm bolt, and some bearings and washers (see pic). The bolt (red) holds it all together (blue forks to frame) and the bearings make the whole thing smoother. the bearings do not work off the inside of the bolt, but rather the frame and the forks. the forks rub against the bearing outer (yellow) through a washer (purple) and the frame rubs against the bearing inner (orange). this setup makes the steering smoother, and involves less wear.
More pics coming.. on another pc.
Rob
r_chez_08
Cornwall, UK
r_chez_08 r_chez_08 is online now
Kart "tester"
Hi,
Ok, yeh that's what I was saying. I can't move it across into the middle or my brake disk hits the frame. I shoulda made my frame 1" wider
Rob
My process of thought:
GO AWAY SPAMMERS!
r_chez_08
View Public Profile
Send a private message to r_chez_08
Find all posts by r_chez_08
Old 12-29-2010, 02:35 PM
r_chez_08's Avatar
Kart "tester"
Ok, more pics. I painted up the frame, a few coats of primer and a coat of red hammerite. unfortunately i ran out, and have a few patches of gray. oops! i ll grab some pics soon
Rob
GO AWAY SPAMMERS!
r_chez_08
View Public Profile
Old 12-29-2010, 10:05 PM
redsox985's Avatar
redsox985 redsox985 is offline
You can fit a much bigger motor in there!
Kart in progress...slow progress.
redsox985
View Public Profile
Send a private message to redsox985
Find all posts by redsox985
Old 12-29-2010, 10:15 PM
r97's Avatar
r97 r97 is offline
before paper and scisors
looks good, tell us how it rides, maybe a vid?
the master of "ya what he said." (sometimes,lol)
r97
View Public Profile
Send a private message to r97
Find all posts by r97
Old 12-30-2010, 03:32 AM
landuse's Avatar
landuse landuse is online now
Its looking good. I am also thinking of building a minibike soon, and your build had given me some good ideas.
View Public Profile
Send a private message to landuse
Find all posts by landuse
Old 12-30-2010, 05:53 AM
r_chez_08's Avatar
Kart "tester"
haha i know, the motor is a bit tiny! i may put my clone in
i will get a vid when finished, but unfortunately, the red paint looks a bit crappy and patchy i need to buy some more MY MONIES!!!!
Rob
Edit: bought some new paint and sprayed it up cost me £7
GO AWAY SPAMMERS!
r_chez_08
View Public Profile
Old 12-31-2010, 06:57 AM
r_chez_08's Avatar
Kart "tester"
new exhaust it has a homemade muffler, and sounds pretty good too. pics later.
Rob
GO AWAY SPAMMERS!
r_chez_08
View Public Profile
Old 01-01-2011, 10:04 PM
robbie robbie is offline
That looks a lot like the yellow bike I built last spring.
robbie
View Public Profile
Send a private message to robbie
Visit robbie's homepage!
Find all posts by robbie
Old Yesterday, 03:38 PM
r_chez_08's Avatar
Kart "tester"
Hi,
i had a little ride with no controls today, needs controls to make it fun though, so back into the workshop i go .
What are peoples opinions on the best way of connecting the cables at the end with out the nob on?
Thanks
Rob
GO AWAY SPAMMERS!
r_chez_08
View Public Profile
Old Yesterday, 03:53 PM
r97's Avatar
r97 r97 is offline
if its for the throttle a cable barrel should be just fine,
i have also seen people use these, not sure what they are called.
for the brakes i would suggest something a little bit stranger like a cable clamp,
also, if you haven't got something setup yet, instead of using zip ties to hold the cable housing, i drill out a normal bolt to make one of these,
r97
View Public Profile
Old Yesterday, 04:17 PM
r_chez_08's Avatar
Kart "tester"
Hi,
Thanks. I have already set up the cable with zip ties. I couldn't be bothered to do any thing else. Shows my laziness! I have some of those wire connector (see pic) which I will try, as they are similar to the barrel. For the brake and belt tensioner I will wrap it through a few times, to make it hold better.
I will see how it goes tomorrow
Rob
GO AWAY SPAMMERS!
r_chez_08
View Public Profile
Old Today, 03:10 AM
landuse's Avatar
Hi r chez
I was wondering if you wouldn't mind showing a diagram with the dimentions of your bike. I was looking at the plans you had drawn up in the beginning of the thread, and they don't look exactly the same. I would like to make one similar to yours, and with my engineering and mechanical skills being practically zero, it would be nice to have some dimensions for my first build. I am going to use a 3.5HP Briggs in my bike.
Thanks
View Public Profile
Old Today, 07:53 AM
r_chez_08's Avatar
Kart "tester"
Hi,
I would do that definanently. I will draw them up asap.
Rob
Thanks for the pics of your bike, as well as the angles. I appreciate it. Could you maybe also tell me how you mounted your rear sproket to the wheel? Also, what size are your wheels?
I like how you have mounted that mudguard. I suppose it isn't something you think about untill you have stuff all over you.
r_chez_08
Cornwall, UK
Hi,
I have some pictures of how I mounted my pulley to the wheel on my pc (I'm on my iPod). They were on this thread, but.. Yeh.
Basically, I had 3 parts. My pulley, a homemade hub and the 11" wheel(from a ride on lawnmower.) the pulley connects to the hub by a keyway, and the hub to the wheel as I filed a little flat, and put a keyway in. Kinda hard to explain. I made the hub and pulleys at school on a lathe. I will grab the pics later.
Rob
r_chez_08
Cornwall, UK
Hi,
Some more pics...
Rob
r_chez_08
Cornwall, UK
Ok I tried to have a ride today.
Problems (in order of priority)
1. Better air filter needed.(would a normal sponge work?)
2:mudguards
3:my belt is wearing down on the tensioner quickly.
4: engine doesn't like hills.
Rob
redsox985
PA
What do you use to tension the belt? The engine may not like hills and bog down because it isn't getting ample air. Could you try running it with out a filter for one test drive to decide if it's your filter or not?
