mini choppa
nawizzel15
here are the wheels im going to be mounting on my chopper only ten inches kinda small for the back but i can always upgrade later sprock cent clutch and chain should com in on tuesday. i would post my finish frame on here but its in school i cant wait to put all the stuff on it now=] thanks to everyone on this site for helping me out
nawizzel15
awsome my chain sprocket and clutch came really really fast here they are
athif
whats the degree of turn u gonna have with that? the sprocket might scrape the ground
nawizzel15
ya i thought about that im just going to make the hub really small so the sprocket is close to the wheel and ill have pretty good turning
RobertD
Administrator
Texas
those look like 4" wheels, and when you turn you're going to hit the sprocket if it's a 60 tooth. I've had the same problem. Get a 6" rear wheel, even a 5 would work, but that small one wont' do it...
athif
looks like the exact one from princess auto, excessive weight causes the bolts to release both sides of the rim and space apart, mine started to split in half so i welded the bolts shut.
