Tpdingo
Ok this isn't anywhere enough to go in the mail build-off but its a little thing I decided to work on.
So I have my little chinese go kart frame with its dead motor mount and it poor gear ratios and everything....so I wanted to make it electric. I also have an old Razor Scooter that hasn't been working in a few years so I decided to take it apart.
So far....the sprocket has been a bolt on swap, and the motor will go on a custom plate which will also be near bolt on with two drilled holes. The old motor mount will probably hold the motor controller and I can hang the batteries through the center of the frame. My hope is also to make some extensions so that the seat can be lifted up a little bit to make the riding position more comfortable. I will post pictures in a little while. What do you guys think? I mean its not going to be fast(well I'll probably 36V mod it just for a little more oomff), but may as well take two pieces of trash and make one piece of good out of it.
